Bizhub C450, computers unable to find printer after network upgrade (ws2012R2)
  • AJ058
    • Feb 2010
    • 24
    Please see post in Konica Minolta or Connectivity Forums
    • 37515
    Re: Bizhub C450, computers unable to find printer after network upgrade (ws2012R2)
    Post this in the Konica Minolta technical forum or the connectivity forum.
    • AJ058
      • Feb 2010
      • 24
      Thanks, thought I did post in KM, but kept getting interrupted, I will re-post in KM
      • AJ058
        • Feb 2010
        • 24
        How do you delete or move post?
        • Iowatech
          Not a service manager
          • 3930
          In the lower right hand corner of your initial post, you will see an entry labeled "edit". Click on that, and one of the options that will appear next will be labeled "delete". Click that, and pay attention, as there is a radio button that you need to click before you click on the next "delete" button.
          One other thing, if you wait too long to do this, you will be denied. The time limit is a feature of this site which is designed to make people to think before they post.
          Good luck.
          • AJ058
            • Feb 2010
            • 24
            Good luck.
            Thanks, would be a nice option to move post to another forum without deleting and re-posting.
            • Iowatech
              • 3930
              That's the thing about needing to think, if you don't do it it usually leads to you having to do more work than you really need to.
              I don't know about you, but that's the way it goes for me anyway.
              Although I don't understand why you are still complaining about this, as all you need to do is think and move your fingers around to change this. Unless you have a physical disability that prevents you from doing those two tasks, complaining about them makes you kind of look bad.
              • AJ058
                • Feb 2010
                • 24
                Sorry the suggestion upset you, I was just suggesting to improve the ease of use of the site. whoever designed the site did a fabulous job, I really do appreciate the work they did.
                Actually I do have a physical disability, had polio at 3 1/2 in 1955, left arm was completely paralyzed, but did not let it stop me from playing football, working construction, building & serving computers, printers and copier sales and service which help regain a little strength back in arm, but no finger control in left hand.
                and my right hand has a badly dislocated thumb (that will require surgery to fix) that causes a great deal of pain while typing. so of course I try to think of ways to make completing a task easier. as I only can type about 5 words a minute.
                Thanks for the pointers and
                Have a very blessed weekend
                Steve Vear
                • chinxxx
                  • Jun 2015
                  • 35
                  Thanks, in advance, for any info.
                  Very interesting. thanks for sharing.
                  ไฮไลท์บอล คู่เด็ดเมื่อคืน ทุกคู่ ทุกแมต ได้ที่นี่ ไฮไลท์ฟุตบอลเมื่อคืน
                  • Iowatech
                    • 3930
                    Steve Vear
                    I apologize. When I was high school a neighbor of ours had had polio as a child and one of his legs was significantly shorter than the other one.
                    Your suggestion didn't upset me, but as I didn't know better it did annoy me. I've been on CTN for a few years and from time to time I've seen others appear to have that same attitude as you while they didn't have a reason to. My post was just a standard response to that sort of thing as I'd prefer to see people do well here rather than pointlessly rail against the rules.
                    • AJ058
                      • Feb 2010
                      • 24
                      I did figure out the problem--s. Somehow the tech I believe defaulted the C450 back to factory settings as two things were changed. Like I suspected, the problem was with the printer setup.
                      1.Printer was looking for the fiery, which it came with, but had been disconnected.
                      2. and the IP was changed to 192.168.0.*** rather than 192.168.1.*** which I did not notice being so close,
                      the prior may have been the fiery IP setting causing it did not ping the IP. as soon as I changed back, all computers can now print.
                      Hope this helps someone else.
                      • Iowatech
                        • 3930
                        On the other hand, this is not going to help anyone ever even a little bit unless you post it here:
                        http://www.copytechnet.com/forums/konica-minolta/
