Bizhub 600 locked up
  • peter@digitalswebsite.com
    • Aug 2012
    • 29
    Powers on, but only the hour glass shows up, never comes ready, try the trouble reset without any luck
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Bizhub 600 locked up
    If you search this forum you will find post about that issue. Sounds like you may need a board.
    • jrf
      • 142
      Probably a faulty flash card
      • Brett GS
        • Jun 2013
        • 154
        Had this before snd was a faulty flash card
        • allan
          RTFM!!
          • 5462
          Yea also had the CF card cause the problem.
          Whatever
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            You guys were lucky. Last time I saw that screen, it cost me a PCB.
              • Aug 2012
              • 29
              Would any of you have a CF card flashed and ready to go I could purchase?
              • darry1322
                • Oct 2010
                • 817
                Same here.
                • Downunder
                  • Aug 2007
                  • 174
                  Go to another BZ600 that you know is working and copy the card contents - then go back to faulty machine and "cut" the contents of the faulty card and copy the good files onto the flash card. DO NOT FORMAT FLASH CARD.
                  You will need to change serial number, and set up copier again, Hard drive, fax etc.
                  There are two cards. System and control.
                  Good Luck.
                    • Aug 2012
                    • 29
                    Do any of you have the cf card firmware you could upload to drop box I only have this one machine, so I dont have the option to get the firmware of another machine
