Di2510 - Please Wait??
  • OutlawTorn
    • Aug 2008
    • 189
    Hello, I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen, and then nothing? It just stays frozen on that message. I have tried umpteen warm resets on the machine, turning the power on and off - but nothing. Has anyone encountered this before? Am I looking at a PWB-A failure? Any help REALLY welcomed!
    cheers.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    The first thing is the flash card on the right side of the scanner. Swap it with another, if that works, rewrite your card. Next swap the card reader and then the MFB 3 that the card reader seats into. You may try unpluging and reseating these boards first. One of these will fix you.
    • OutlawTorn
      • Aug 2008
      • 189
      thanks for the reply fixthecopier, how do you find this sorry?
      • Scorotron Wizard
        • 28
        Does the machine run any motors because a really common problem is the toner add gearbox chews up and the machine runs for 5 mins while it tries to add toner.
        The Wizard
        To the Pessimist the glass is half empty
        To the Optimist the glass is half full
        To the copier engineer...
        The wrong glass has been supplied, it should be 50% smaller Haha
        • OutlawTorn
          • Aug 2008
          • 189
          Ok guys, HELP! I have replaced the toner hopper drive unit and cleared/re-installed the firmware onto the flashcard twice now. Still nothing. Should I purchase a new flashcard? do they get faulty?
          Any help muchly appreciated, at a bit of a loss here!
          • perdana
            • Jan 2008
            • 62
            I think it was NV Ram.
            • OutlawTorn
              • Aug 2008
              • 189
              NV Ram? where do I locate this? could someone explain a little further? thank you.
              • Johnny_B500
                • Mar 2007
                • 24
                It's a faulty memory or scan chip by the NIC card. Remove one or the other to test.
                • OutlawTorn
                  • Aug 2008
                  • 189
                  NIC card? is this the network card? could you explain a little further thank you?!
                  • Johnny_B500
                    • Mar 2007
                    • 24
                    I have found that this is usually caused by a defected SU-2 or Memory.
                    Firstly check the connection between the ROM board and the MFB3 board. If that doesn't help (in most cases ot doesn't) then remove the SU-2 or memory and see if the machine starts up and goes to the copy screen.
                    Hope this helps!
                    • OutlawTorn
                      • Aug 2008
                      • 189
                      Just wanted to say thanks for the help on this issue everyone! I ended up disconnecting the network card and re-seating it and this solved the problem. Weird, but hey, I'm happy. Cheers again.
                      • Johnny_B500
                        • Mar 2007
                        • 24
                        No problem and I'm glad you were able to resolve it!
                        • copychef
                          please wait
                          xxx
