minolta di470 code 0090
  • garrycmsi
    • Jun 2015
    • 22
    [Error Code] minolta di470 code 0090
    developer motor wont always start i can get it to spin by manually turning it. is it a bad motor? or is it like some kyoceras that give motor error codes when interlock switches fail
  • Hansoon
    • Sep 2007
    • 3380
    Re: minolta di470 code 0090
    We had a lot of these machines in the past and never ever a single C-0090 service code. Only thing I can imagine is an obstruction in the developing unit/drive. Did you check if the mag roller is turning freely? Occasionally we had the inner bearings go bad.
    Hans
    • garrycmsi
      • Jun 2015
      • 22
      thank you hans,
      developer unit turns freely, motor will turn every so often and makes a buzzing sound when it decides to turn
      • Hansoon
        • Sep 2007
        • 3380
        Garry, when those stepper motors make a buzzing/whining sound it is most of the time some kind of overload.
        Hans
        • laitang
          • Nov 2012
          • 627
          From SM:
          Developing Unit Drive Motor (M1) part no: 9314-2200-11
