So I have little production experience overall but I have worked on these machines enough to feel confident.
I have this c5500 that is shadowing/smudging black a little bit per page. It is very consistent in location when it comes to "feed direction". Cross direction however it does move. Parts replaced/swapped. Drum, belt, fuser, charge unit. Developer unit will be next but it seems more of a timing thing to me as it is in the same spot of feed direction. I have played with some timing adjustments with no luck. Take a look and see if any body has any suggestions. Thanks.
