+224e Weird fax problem
  • stefano111
    • Apr 2013
    • 6
    [Misc] +224e Weird fax problem
    hi all
    I have a strange fax issue with a develop +224e which is basically the konica c224e whereby we upgraded it to have a fax kit as the customer wanted to get rid of there old canon fax machine (which was working fine) however when you plug the fax line into the 224, you get a dial tone which is noisy and nothing can be sent just keeps re-dialing and fails to connect. the dial tone is clean on the canon.
    things ive tried
    no filter and straight into the socket
    with filter into socket
    slowed speeds
    checked for 50v in telephone socket
    swapped the fax unit for another fax unit
    changed cables and the fax lead is a manufacturer one and brand new
    turned on and off ecm
    i can call it but it doesnt receive faxs
    anything i could be missing?
    thanks in advance
  • Gift
    • Mar 2011
    • 2459
    Re: +224e Weird fax problem
    Is it obviosly noisy or just a bit? I always have a cheap line phone in my car - it's somewhat better to listen after noise issues.
    We had some faulty FKs in the past, brand new and not working properly during installation so it might be aother case of bad luck at your end.
    • mo0651
      • 1054
      Did you test the line from the socket with a test phone? Not thru the machine but the wall? Is the customer using a DSL set up?
      • stefano111
        • Apr 2013
        • 6
        @gift
        we havent tried a phone straight into the socket but the customer has a friend in BT who he got out to test the line and said it was all ok, and it is pretty noisy.
        weve put 2 brand new fax kits into it and both the same but my colleague did notice on the back of the canon they've got it has some kind of built in filter?
        @mo6501
        yh the customer has a dsl setup
        again not plugged a phone straight in just through the fax machines
        thanks for replies got me stumped
        • BR549
          • 111
          Did you set the fax country code and then initialize the fax kit?
          • stefano111
            • Apr 2013
            • 6
            yes mate as per manufacturers instructions
            • nmfaxman
              • 1702
              Install a DSL filter on the phone line.It is probably tapped into their internet signal.
              • stefano111
                • Apr 2013
                • 6
                it has a filter, does sound worse without though
                • wayniezaza
                  • Jun 2015
                  • 5
                  A bit of a random suggestion, but maybe try change the country dialling code to another country
                  strange suggestion but has worked for me before.
                  • stefano111
                    • Apr 2013
                    • 6
                    ok mate will give that a try,
                    open to any other suggestions too?
