Severe paper curl from built-in finisher
  • Bob Wescott
    • Sep 2013
    • 14
    [Misc] Severe paper curl from built-in finisher
    Have a bizhub 363 that is reasonably happy, but paper curls excessively exiting from FS-529 finisher, sometimes pushes previous sheet(s) out of order or on the floor. Is there a way to decurl in this finisher? Tried everything with paper.
  • allan
    RTFM!!
    • 5459
    Re: Severe paper curl from built-in finisher
    Check your paper quality and fuser temperature.
    Are u using generic toner?
    Whatever
    • Bob Wescott
      • Sep 2013
      • 14
      We tried very good paper that works like a charm elsewhere. Strictly OEM toner. I thought there was a de-curl adjustment someplace. We'll check the fuser. Thanks!
      • emujo
        • Jun 2009
        • 3009
        Remove the finisher and run copies...No curl---problem with FS, Curl---problem in fuser...Divide and conquer, let us know what you find. Emujo
        • allan
          RTFM!!
          • 5459
          The B363 does not have curl adjustment. I had to drop the fuser temp on this model before to get the finishers to stack correctly. I think the machine does have a setting that would allow you to change between quality and production mode.
          Whatever
          • Bob Wescott
            • Sep 2013
            • 14
            Will do. I'll let the forum know what transpires. thanks.
