Customer called about an hour ago with error c5102 on bizhub c203. I checked manual and it appears to be main motor/transport motor related. Is this usually a motor change necessity or is it usually something putting added stress on motor that needs to be addressed. I've had different machines where the fuser unit or drum unit or dv init need to be repaired or changed. Any information is very much appreciated. Frank/ActionPhotocopy
Bizhub c203 with error c5102
Re: Bizhub c203 with error c5102
Really not so bad. The boards stay in the "cage" so it's one big piece. Lots of screws a couple fans and ribbon cables to get out of the way. Just remember when you boot up you'll probably get the code. You have to trouble reset it.Comment
Frank, don't forget to take out that easily forgotten hidden screw under the white ribbon cable support at the right hand side of the cage. Otherwise the cage will not come out. Just did 3 weeks ago that motor for the same reason. I took one from a junker, which I have a lot at the moment, cause I'm replacing as much as possible of these series with the following up C-280/360's. Did I say I started to HATE the C253/353 series..........?
HansLast edited by Hansoon; 07-07-2015, 05:03 AM.“Sent from my Intel 80286 using MS-DOS 2.0”
Hi we have had a few main motor M1 go its not unusual.Its a bit of a job to replace it as the cage has to come off to get access, its on the left hand side as you look at it,Part noA02EM10300, we found practice makes it half hour job !!! Hope this helps.Comment
Hans
must admit apart from toner supply issues (which I haven't had many) I find this range of machines to be good but a bad run good change that option.
paul.Comment
