C550/650 - black streaks
  • theprintshop
    • Jun 2015
    • 15
    Hello everyone,
    I am getting these weird black streaks on my printouts - I tried to clean what I could but I'm not sure where it's coming from.. any ideas? --- I've provided a picture of what it looks like
  • Jazzwcs
    • Jun 2012
    • 40
    Re: C550/650 - black streaks
    That looks like a bad black Imaging unit. I would pull it and examine the drum for scratches and void areas. You should probably check transfer belt and cleaning assembly. Otherwise you should pull out write unit and make sure no toner/developer has fallen on the write glass window.
    • konica7022
      • Nov 2008
      • 132
      Yes thats correct, clean black IU and the Lamp under neath and then check again
      • minimerlin
        • 851
        May be worth pulling the fusing unit and giving the guides below it, on the machine frame a good clean, and also the entry guides of the fuser itself.
        Please do not PM me without asking first.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Looks like drum scratches.
