Keycounter socket location PRO951
  • patk
    • Jun 2008
    • 56
    Have not been able to find location of the keycounter socket on bizhub PRO 951. Anyone know, doesnt appear to be in any manual Ive seen so far
    Cheers
    Pat
  • allan
    RTFM!!
    • 5462
    Re: Keycounter socket location PRO951
    Here comes the best clue i can give. CN35 on the PRCB and CNT2(Fknows?).
    The only instance i could get in the manual is on a diagram.
    That does show the pin layout.
    Search for the words key counter in the manual and there would be a couple of clues.
    I would not be surprised if the socket on CN35 is empty.
    I don't think they what you to use it. Its there, but no supporting documentation!
    Whatever
    • tech51
      • 846
      There's a small panel on the rear of the main body which you have to unscrew. The socket is behind that.
      If you look at the machine from the back its just below the left hand doc feeder hinge.
      • patk
        • Jun 2008
        • 56
        Thanks but we do not have small panel in that position or anywhere on back of machine body
        Cheers
        • patk
          • Jun 2008
          • 56
          CN35 is connected - 4 yellow wires which unfortunately join the loom with a million other yellows
          Cheers
          Pat
          • allan
            RTFM!!
            • 5462
            Well its CN35 connector the key counter only use 4 wires.
            Dont take my work for it but i think shorting pin 2 and 3 would lock the machine in key counter mode. Its SGND and Set_KC. I would do that with a low rated like 250mA 5V fuse.
            Whatever
            • patk
              • Jun 2008
              • 56
              My error - CN35 has 4 yellows (edited above). I've found the key counter connector now, its in the space above HV unit 1, identified by pins 1 and 2 being loop connected as per the wiring diagram.
              Thanks for help
              Cheers
              Pat
              • allan
                RTFM!!
                • 5462
                Thanks for help
                Cheers
                Pat
                I am never sure if it should switch to positive or to ground. All sensors and solenoids switch to ground.
                That means Pin 2 (Key Counter set) and Pin 1 (24V supply) must be open (not connected) to disable the machine? That means its switch to positive.
                Are you connecting a coin vendor?
                The way of doing things with this machine is with IC cards that can be loaded with credits.
                Not a machine i would expose to the public.
                Whatever
                • patk
                  • Jun 2008
                  • 56
                  Although 24v supply is on pin 1 on CN35, its on pin 4 on the key counter socket CN61A, The two pins connected are Key Counter Set and SGND.
                  No, not connecting coin vendor, I'm connecting a CPAD unit for PaperCut MF.
                  Cheers
                  Pat
                  • MAUro
                    • Feb 2018
                    • 1
                    Cheers
                    Pat
                    Hi, i had the same problem, the conector 1&2 must be connected. Cheers
