Replace imaging unit K
  • Jhonjon
    • Sep 2013
    • 208
    Good day,
    Gentlemen, I need your help regarding Konica Minolta Bizhub C35. The machine indicate replace imaging unit K, but when i replace the unit the same message appear. I try to clean the chip on the machine which contact to the drum unit but still the same. Machine is working scan, copy, print and fax, only the message bother the costumer. Any suggestion is highly appreciated...Thanks...
  • allan
    RTFM!!
    • 5462
    Re: Replace imaging unit K
    Are u using after market chips?
    It happens from time to time with those chips.
    Whatever
    • Jhonjon
      • Sep 2013
      • 208
      We are using all original consumables and parts...
      • allan
        RTFM!!
        • 5462
        Then there is a bulletin out for that. Its a crap machine. TAAU1100165EN00
        There is only one way out of that, actually three.
        Replace MFPB
        Repair MFPB
        Replace machine
        Whatever
        • JSC
          Gimp
          • Dec 2006
          • 618
          Its a crap machine.
          Its not not as good as that....
          The gene pool could use a little chlorine.
          • Jhonjon
            • Sep 2013
            • 208
            Replace MFPB
            Repair MFPB
            Replace machine
            Thanks for your feed back guys. I will try it, and inform you for the result...
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              interesting that it would suggest replacing the mfp board when as always the tc and iu csic harnesses plug into the printer control board.
              Make sure none of the contacts for either the toners or the IUss are damaged and shorting to the sheild - it will disable communication for both the toners and IUs even if just one is shorted.
