Emptying the Waste Toner Bottle
  • DaisySteiner
    • Jul 2015
    • 7
    [Misc] Emptying the Waste Toner Bottle
    Hi Guys
    Does anyone know how to empty a Waste Toner Bottle on a Konica C224.
  • Splinkter
    Re: Emptying the Waste Toner Bottle
    I wouldn't recommend it as it's likely to just create a mess.
    Your supposed to replace them.
    • DaisySteiner
      • Jul 2015
      • 7
      Its okay , Ive figured it out and its now working.
      Yeah I know you are not meant to but it was a dire situation.
      Thanks anyways
      • hotfuser
        • 180
        Thanks anyways
        if you empty it take the see through window off and clean it so you do not get the waste toner full when replaced.
        • DaisySteiner
          • Jul 2015
          • 7
          Thanks Guys
          In the end I had to unscrew the clear plastic clip and empty it out. I wasn't expecting this to work , must of been a fluke , but it did . I have x2 new WTB arriving today so just needed a temp fix.
          • allan
            RTFM!!
            • 5462
            It's that almost all of the time. IT guys have tried and failed almost every time. Just clean the thing before you pop it back in.
            Whatever
            • DaisySteiner
              • Jul 2015
              • 7
              Beginners luck , or I am just plain fabulous
              Yeah , I made sure I cleaned it and let it settle.
              Thanks all x
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                When the customer doesn't have a spare I simply use the vacuum cleaner to empty it and the detection window.
                no mess, ever.
                I then empty the vacuum into a thick bag and toss it in their garbage and warn them its not happening again and to order a bottle.
                • rrrohan
                  • Sep 2011
                  • 1977
                  ive completely removed the window section and covered the hole with duct tape once while waiting a day for a replacement to arrive
                  its not as messy and if its only for 2 days at most you will be fine
                    • 14728
                    We just empty them. From the C250 all the way up to the e series. It is easy and saves a lot of money.
