I had to swap the mfp and nvram from a working machine in our warehouse do to failure.
The result was a message that said License error management occurred and the machine seems to work other than that.
How do I recover or repair management data when old nvram and mfp was not any good to back it up?
The original issue was an ongoing black screen on display that would take several reboots to fix one of our technicians went for that call and scrambled the machine with the other nvram. The mfp board does not even work now and the machine currently has the other mfp and nvram on it with the serial and counter for the stripper machine.
LICENSE ERROR MANAGEMENT OCCURED [message} is the problem I want a resolution to. I believe the other black screen and reboot issues was the bad nvram and mfp board.
Thanks for any help you can give me.
