C360
  • Mahmood
    • Jun 2015
    • 13
    [Error Code] C360
    hi
    C360 with error code C5601 firmware updated and PRCB changed but still the same error.
    any idea.
  • allan
    RTFM!!
    • 5462
    Re: C360
    Did you open and close the front door to reset?
    Does the code pop up at startup or during a job?
    Whatever
    • Mahmood
      • Jun 2015
      • 13
      Re: C360
      yes I did, after resetting the error code machine will come in ready state then code will appear again.
      • allan
        RTFM!!
        • 5462
        Re: C360
        Disable the HDD and do a ram test from service mode. The code explanation is vague so it could be a couple of things. Even keep the lan cable unplugged. Disable things like the fax and AU's. U can use [trouble isolate] for some things.
        try to eliminate anything possible.
        You can even try a machine data clear or just a error data clear.
        Whatever
