C6501
  • selmila
    • Aug 2012
    • 133
    C6501
    is it possible to use the printer function without using fiery on c 6501?
  • allan
    RTFM!!
    • 5462
    Re: C6501
    IC-408 comes embedded with the machine it is a fiery but is listed as optional. You get 2 other external controllers. If the external controller malfunction you need to change the controler setting and use the internal one. You would have to recalibrate if color matching is poor.
    The brochure shows a system without any optional controllers. And the only driver available is a PS3 driver.
    so i am guessing yes.
    Whatever
    • Mick01
      • Nov 2012
      • 362
      Re: C6501
      Hi,
      The answer is no. You need a RIP to be able to print. There are four options
      IC-408 (EFI embedded Rip).
      IC-303 (early EFI Server type Rip).
      IC-305 (replacement EFI server type Rip for the IC-303).
      IC-304 (Creo server type Rip)
      If you have a production configuration (any of the large production options FD-503,SD-506, FS-521) then the IC-408 will not work.
      Hope this helps
      • selmila
        • Aug 2012
        • 133
        Re: C6501
        Ok so there is a possibility to use the machine without any controler. Could guide me to change the controler settings.
