Error code sc52-07 0n 7085??
  • excanonguy
    • Jun 2008
    • 173
    The other tech I work with was unable to clear the code and is on holidays this week.....and I know almost nothing about this machine! It apparantly also had a sc29-04 code as well before this one came up, and thoughts opinions or suggestions greatly appreciated!!
    Steve
  • Luther
    • May 2006
    • 682
    52-07 is main body cooling fan abnormality
    • excanonguy
      • Jun 2008
      • 173
      Does the fan usually die, or is it more likely to be a pwersupply or fuse issue? By the way the machine has over 4 million on it...Thanks!
      Steve
      • deep
        • Jun 2008
        • 208
        You can never tell what will be the exact trouble but the most possible is the fan motor FM6.
        Kenny
        • excanonguy
          • Jun 2008
          • 173
          Great,thanks for your help I have got to go take a look at it today,its almost an hour and a half from our reg territory, so at least this will give me something to look for!
          Steve
          • excanonguy
            • Jun 2008
            • 173
            Just wanted to post the follow up to this , I swapped the fans around and still got the same error ,so I could rule out the fan, so I started checking for power loss, and the 24VDC out put on power supply #2 was dead, a new power supply fixed the problem.
            Steve
            • RockETop
              Curmudgeon at large
              • Apr 2007
              • 171
              I just replaced a DCPS2. watch yer knuckles.
              • excanonguy
                • Jun 2008
                • 173
                LOL thanks for the warning,too late!!!
