Disable doc feeder on bh363?
  • Motormount
    • Sep 2010
    • 78
    [Misc] Disable doc feeder on bh363?
    Is there an admin or service setting to disable the doc feeder whilst I wait on the latch? I can't find one in the manuals or at the control panel. Or just disconnect the cables (wish it were a quick disconnect, like the older models).
    Thanks,
    RB
  • Flash
    • 378
    Re: Disable doc feeder on bh363?
    You should be able to go into the service mode, select System 1, and then select Trouble isolation and unset the document feeder.
    • wseyller
      • Sep 2012
      • 1129
      Just have the customer stick a ream of paper on the back corner of the doc feeder lid. It will work just fine while you wait on the part.
      Sent from my XT1254 using Tapatalk
      • copyrooks
        • Oct 2013
        • 207
        You should be able to go to service mode and I believe system 2 look for adf settings and then just unset the feeder selected. Could be mistaken with the 224 models but worth a shot.
        **turns out that's for 224 so yeah, double checked the manual and trouble isolation would be the way to go
        • Motormount
          • Sep 2010
          • 78
          Thanks Flash. Yep, another look at the manual and that's where it is. Yesterday I couldn't see it - HDTV (hump day tunnel vision) I guess - could only see Friday from there.
