C-2557 on a C554e
  • Guy Milner
    • Nov 2013
    • 61
    [Error Code] C-2557 on a C554e
    Hi ....
    Ongoing problems with error code C-2557 on a C554e.
    We have changed the K dev unit and K toner, but still got the code ( intermittantly )
    Vacuumed out the hopper and visually checked all the workings within it.
    We are taking a motor and sensor off of a C224e today to take up for testing.
    Anyone experienced this on the C554e?
    Thanks,
    Guy
  • Max
    • Oct 2011
    • 555
    Re: C-2557 on a C554e
    There is a mod bulletin for the c224e regarding this issue. I believe it will be the same for 554. You need to change the bushing.
    • D Colour
      • Oct 2008
      • 213
      We had this problem on a 224e. Forced toner, code went for a day, then replaced the dev, code went for a week. Turns out a plug was loose. If you remove the output tray, there is a sensor on the black dev, check it.
      Everything that has a beginning, has an end.....
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        I had a new install of a c454e do this. After trying everything for 3 weeks I found a bulletin on the issue I was having. The paddle inside the sub hopper is not moving correctly against the sensor so the unit does not add toner to dev unit. There are cut-in serial numbers for the other models but not the c454e series. I ordered the sub hopper assembly and have not heard from them in 2 weeks.
        I am not logged in but search for c255x in the bulletins if you have access to KM.
        • splblazer91
          • Jul 2014
          • 204
          Replace the hopper assy. Have never had a developer unit go bad on one of these. Its always the dang hopper.
          • malthus
            • 29
            modified bushing available from minolta original one seized up in hopper and threw up code deepending on colour
            • Guy Milner
              • Nov 2013
              • 61
              We have replaced the motor and p.i sensor for K. So far, so good.
