Mosfet Transistor
  • AlbertK
    • Jul 2014
    • 90
    Mosfet Transistor
    Good day all
    Do any of you know if I can use a K3326 instead of a K3565 mosfet on a Kyocera FS-6030mfp power supply ?
    Regards
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: Mosfet Transistor
    you'll probably need to call the transistor supplier/manufacturer for specs(pins, current, voltage, beta value) to see if they are compatible.
    you can easily find 2SK3326, 2SK3565 datasheet (a glance tells me they are very different).
    2sk3565.pdf 2SK3326.pdf
    Idling colour developers are not healthy developers.
    • AlbertK
      • Jul 2014
      • 90
      Thank you sir....Indeed they are different, however, I took a chance and used the Transistor on another section of the same PCB that had the one I actually needed....so far it works well. I had to buy some time as new parts are not readily available.
      Keep well
