KM2530 driver for Mac OSX 10.8.5
  • Strouty
    • Feb 2014
    • 16
    I have the copier printing, but I can't get any of the features working. It will duplex, but I can't select paper sizes or anything. So my ledger size things are printing on Letter paper. I had this fully working, then when I went to install another printer, the mac stock drivers were gone, so I was told to delete everything from the Printers file and the PPD file and restart. The mac repopulated all the drivers, at least I thought it did. The one for this copier I believe was listed under a KM2540 KDPL, now I can't find it at all. Anyone know what stupid thing I am doing wrong?
    Thanks.
  • qbert69
    • Mar 2013
    • 1152
    Re: KM2530 driver for Mac OSX 10.8.5
    First off, use Spotlight to quick find and open your programs...keyboard shorcut is CMD+spacebar. CMD=cloverleaf key.
    Open (...from Spotlight) Safari and in the URL address space type:
    localhost:631
    this opens CUPS (Common Unix Printing System) control webpage.
    If CUPS is not enabled, open the "Terminal" program and at the command line prompt type the following and hit enter:
    cupsctl WebInterface=yes
    once enabled, you can refresh the Safari webpage for "localhost:631"
    CUPS will give you "finer grained" control for settings and setting up and maintaining your installed printers and print drivers.
    Good Luck!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
