FS-1128 grey vertical lines when copying
  • Centvrion6
    [Electrical] FS-1128 grey vertical lines when copying
    We've got an FS-1128 that has vertical lines when copying from glass or the ADF.
    No image at all, just full background of crisp gray lines.
    Prints look fine. Customer has been (printing only) with it for a few days now.
    I've replaced the small square lamp PWB and the Scanner PWB with used items, but still no fix.
    Firmware updated. Tech support no help at all.
    Any ideas??
  • Cartaos
    • Feb 2010
    • 6
    Re: FS-1128 grey vertical lines when copying
    Clean the optics, use compressed air.
    Check firmware
    Then with original Kyocera color chart
    - U425
    - U411
    Adjust the home position
    - U068 (my favorit +10)
    • Intone
      • Apr 2015
      • 68
      we had to replace a scanner unit on a m2535 series for similar issue recently.
      • subaro
        • Oct 2010
        • 1274
        had that problem long time ago and had to replace the scanner flat white ribbon cable.
        • kyogenius
          • Jul 2012
          • 136
          its more likely the white data cable thats damaged or the screws on the board on the scanner that have been tempered with or accidentally moved
          failure is not an option !
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            QA# A398_2H9_004
            u068, set to "+11" (already mentioned up top, but there's the QA for it FYI)
            There's another QA somewhere that has mention this and basically ask us to tape a black strip over the left portion of the slit glass like in the bigger machines.(not sure on this one)
            Idling colour developers are not healthy developers.
            • jam-o-matic
              • Oct 2012
              • 72
              +1 Ditto on the flat white data cable from the scanner. Mine had good internal prints & those digital lines when copying
