Ecosys P2135dn - Offline
Re: Ecosys P2135dn - Offline
That's a strange one, and looks like they need to check their network. Lets assume that physical part of the network and that ancient Win XP are working as intended. Though you can easily check it out by bringing your own Win7/8/10 laptop and your own network cable (crossover or straight, doesn't matter since today's network cards are doing auto negotiation by default), and connecting the printer directly to it and assigning proper fixed ip addresses to both for the sake of testing.
On the printer properties under ports tab, double check if you have the correct ip address as port there, that no other device on network is using. Also check with them if there are any specific network security policies applied.
