C6950 on a 7550ci
  • Tonerkiller
    • Oct 2012
    • 668
    C6950 on a 7550ci
    I have a C6950 on a 7550ci. It will not reset with a 163. Has anyone else ran into this problem?
  • LNorris
    • Sep 2008
    • 645
    Re: C6950 on a 7550ci
    looks like a wiring issue with fuser. are the connectors plugged in?
    6950 Fuser IH PWB communication
    error
    No response is received in 30ms since a command is sent to IHCPU.
    A checksum error is detected 10 times in succession.
    Power source PWB 1. Confirm that the wiring connector is
    firmly connected and, if necessary, connect
    the connector all the way in.
    Power source PWB (YC9) and Feed
    PWB 1(YC4)
    Power source PWB (YC3) and Fuser IH
    PWB (YC1)
    2. If the wiring is disconnected, shorted or
    grounded, replace the wiring.
    3. If the +24V output is not given by the
    power source PWB (YC9), replace the
    power source PWB.
    Feed PWB 1 1. Confirm that the wiring connector is
    PWB (YC1)
    feed PWB1 (YC27), replace the feed
    PWB1.
    Fuser IH PWB 1. Confirm that the wiring connector is
    connect the connector all the way in.
    Fuser IH PWB(YC4) and Engine PWB
    (YC26)
    3. Replace the Fuser IH PWB (see page 1-
    5-74).
    Engine PWB 1. Check the engine software and upgrade
    to the latest, if necessary.
    2. Replace the engine PWB (see page 1-5-
    • Zackuth
      • Aug 2009
      • 448
      I had a C6950 error on a 3051ci, turned out to be the low voltage board.
      If at first you don't succeed, redefine success
      • Tonerkiller
        • Oct 2012
        • 668
        On the high speed color models, the solution to this code is the Ih board
