I have a KM 5035 with PF 75, PF 75 is jamming cant put finger on the part, I thought primary feed, Replaced still jamming right there! Just looking for ideas, reading a parts order.
Very common for the one way bearing gear in the middle of shaft off of feed clutch, to go out and slip.
PF-75 parts book page 6 part# 54106280 pulley-S3M-18-OW. needs to be replaced if it is slipping.
It controls the pickup tires on the left side of the pf75, not the feed and sep tires but the pickup grey ribbed tires
the one way bearing gear is supposed to grab the shaft as it turns and in turn turn the tires, but if it slips, no turn of the tires.
sometimes the shaft needs to be replaced, but I have just kind of ruffed it up a little with a file where the gear sits on it
Thanks alot i just ordered the one way and mylar also feed rollers.
Thanks alot pal, i just ordered all the parts.
Bill
Hi
What was the jam code?
I was working on one today, been a while as I work on canons now mostly.
I found on a Taskalfa 420i J21 exit jam was caused by the conveying section sensor which serves the lower trays or in this case the pf75 getting the same code when it did try to print. stuck half way out the exit unit, other trays work fine.
I am getting no feed from the tray so have quoted clutches and rollers, plastic clips that hold all in place are Ok. I swapped clutches around and rollers but still no joy. I will check out the mylar and bearings.
