CS-2550 Firmware Update
  • BabblingXombie
    • Jun 2015
    • 32
    Hi Guys i need help updating firmware for a CS-2550
    Any help would be appreciated. Thanks
  • copydocinc
    • Mar 2015
    • 263
    Re: CS-2550 Firmware Update
    Is it the instructions you need?
    Turn off the power and unplug power
    Remove the rear cover and insert the compact flash in its hole, with the label facing the rear of the machine
    plug in the power and turn on the machine.
    Do not turn off the machine until the panel says "complete"
    Is it the firmware you need?
    There are many places on the internet that you can download the firmware.
    caution, it may not work if you use a compact flash card bigger than 64MB
    and make sure to format it first.
    Curious--why are you upgrading the firmware now?
    If this machine has never had the firmware upgraded, it is possible that the new firmware version is too far advanced
    for the old firmware version to accept it and it can end up in a constant attempt to upgrade and never come out.
    which will force you to replace the main pcb.
    It happened to me once on a 3035 model.
