Error c-3252
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Error Code] Error c-3252
    replaced the motor today but It is very hard to turn when installed so I need to clean out the recycling coil, I assume this is located within the "image formation holder" is this correct and can anyone give additional insight into this Issue? Since tho motor is in the rear of the machine and the coil is in the front is there a cleaning unit that gets plugged up..... Thanks
