Has anyone found a supplier who sells a rebuild kit or single drum and blade for these Image units? Drum units are avail., but not the drum or blade by itself. These units are very simple to change out the D & B. I'm looking for a parts supplier for these individual items...Any luck? Thanks!
Replacement drum and blade for Kyocera FS C2526 MFP
Re: Replacement drum and blade for Kyocera FS C2526 MFP
Manufacturer only supplies the kit code as well as I'm sure you already know. Might be out of luck on this one
