Booklet maker crease/ripple intermittent bf730
  • bollard
    • Nov 2012
    • 40
    Got issues on and off when doing booklets only , saddle stitched .
    Stripped and cleaned all main rollers within booklet maker to no avail.
    Anyone had issues with the BF730 units ?
  • qbert69
    • Mar 2013
    • 1152
    Re: Booklet maker crease/ripple intermittent bf730
    Does the ripple/crease travel the same direction as the paper travel?...or is the ripple/crease perpendicular to the direction of paper travel???
    Is the toner fused onto the paper before the crease or after the crease???
    I have seen instances where just before a registration roller, a mylar guide would be worn unevenly. This would cause the paper to contact the registration roller at different points unevenly, thus creating a crease in a particular point in the page longitudinal with the direction of paper travel.
    Good Luck!
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
