5501i jam codes 4101 and 4001
  • bcopier2815
    • Oct 2015
    • 42
    I have a5501i where I get jam codes 4101 and 4001. I replaced the Mid motor 302K994310 and gear 302LL24030 because they were worn and grinding. I still get the jams. Drawer 2 works perfectly. I have also swapped feed units with no joy. Any thoughts?
  • fornerm
    • 82
    Re: 5501i jam codes 4101 and 4001
    Hello,
    i have now the same. Machine with 248K, Any Solutions ?
    mfg
    Markus
    • Scottb
      • Apr 2013
      • 306
      Originally posted by fornerm
      Hello,
      mfg
      Markus
      in your parts manual check FIG. 17 Drive Section 2, part 11. these clutches will rust and cause all kinds of mischief while you're at it check the one on the vertical path roller as well it will be directly behind this unit and I usually replace it at the same time.
      • fornerm
        • 82
        Thanks Scottb I thought so too, have now replaced one in the clutch block,
        had only one there, the others cleaned, rust was not visible in the four,
        but they are pretty polished already on the friction disc in the clutch, the worst of mine Opinion,
        I swapped, it was the auxiliary clutch at the 1st Feeder.
        I'll wait and see if things are going better now.
