Kyocera Taskalpha 4550ci user login
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    How do I disable the user login feature?
    Need advice on a Kyocera Taskalpha 3550_4550_5550ci series color mfp. We do a ton of work on Ricoh,Canon and Konica but not a lot of Kyocera's. A local customer picked up a super low meter unit but the display is asking for a user login. In an effort to be very specific...... I am not asking for the admin or command center logins---just want to remove the user login requirement... Do I just reset this by initializing the machine in U021 mode? Also, tried to enter service mode (manual says 10871087) but service mode did not come up. Does the user login condition also lock me out of the service mode on this model or am I missing a something?
  • blazebusiness
    • 1257
    Re: Kyocera Taskalpha 4550ci user login
    {Also,posting the following default Admin password info info for the color Kyocera's that I ran across just in case it might help others in the future:}
    Command Center Username & Password
    FS-C2526MFP----------admin00
    FS-C2626MFP----------admin00
    205c------Nothing when default admin00
    255c-----------------admin00
    250ci----------------admin00
    300ci----------------admin00
    400ci----------------admin00
    500ci----------------admin00
    552ci----------------admin00
    2550ci-------------Admin Admin
    3050ci-------------Admin Admin
    3550ci-------------Admin Admin
    4550ci-------------Admin Admin
    5550ci-------------Admin Admin
    6550ci-------------Admin Admin
    7550ci-------------Admin Admin
    Machine-------Username & Password
    FS-C2526MFP----- Admin Admin
    FS-C2626MFP----- Admin Admin
    205c ------------Admin Admin
    255c ------------Admin Admin
    250ci -----------2500 2500
    300ci----------- 3000 3000
    400ci----------- 4000 4000
    500ci----------- 5000 5000
    552ci----------- 5500 5500
    2550ci---------- 2500 2500
    3050ci-----------3000 3000
    3550ci---------- 3500 3500
    4550ci---------- 4500 4500
    5550ci---------- 5500 5500
    6550ci---------- 6500 6500
    7550ci---------- 8000 8000
    --------------------------------------------And the Monochrome logins:------------------------------------------------------------------------------------------------------------------------------------------------------
    Command Center
    Model ============Username Password
    Monochrome
    FS-2100DN-----------Admin Admin
    FS-4100DN-----------Admin Admin
    FS-4200DN-----------Admin Admin
    FS-4300DN-----------Admin Admin
    FS-1028MFP------------admin00
    FS-1030MFP------------admin00
    FS-1035MFP------------admin00
    FS-1128MFP------------admin00
    FS-1130MFP------------admin00
    FS-1135MFP------------admin00
    FS-3040MFP------------admin00
    FS-3140MFP------------admin00
    FS-3140MFP+-----------admin00
    FS-3540MFP------------admin00
    FS-3640MFP------------admin00
    FS-6525MFP----------Admin Admin
    FS-6530MFP----------Admin Admin
    305-------------------admin00
    300i------------------admin00
    420i------------------admin00
    520i-No Default-------admin00
    3500i---------------Admin Admin
    4500i---------------Admin Admin
    5500i---------------Admin Admin
    6500i---------------Admin Admin
    8000i---------------Admin Admin
    Machine Username & Password
    Model# //Username Password
    FS-2100DN Admin Admin
    FS-4100DN Admin Admin
    FS-4200DN Admin Admin
    FS-4300DN Admin Admin
    FS-1028MFP 2800 2800
    FS-1030MFP 3000 3000
    FS-1035MFP 3500 3500
    FS-1128MFP 2800 2800
    FS-1130MFP 3000 3000
    FS-1135MFP 3500 3500
    FS-3040MFP 4000 4000
    FS-3140MFP 4000 4000
    FS-3140MFP+ 4000 4000
    FS-3540MFP Admin Admin
    FS-3640MFP Admin Admin
    FS-6525MFP 2500 2500
    FS-6530MFP 3000 3000
    KM-2560 2500 2500
    KM-3060 3000 3000
    620 6200
    820 8200
    181 1800
    221 2200
    255 Admin Admin
    305 Admin Admin
    300i 3000 3000
    420i 4200 4200
    520i 5200 5200
    3500i 3500 3500
    4500i 4500 4500
    5500i 5500 5500
    6500i 6500 6500
    8000i 8000 8000
    • subaro
      • Oct 2010
      • 1274
      1 Press the System Menu key.
      2 Press [User Login/Job Accounting].
      3 If the user authentication screen appears, enter
      your login user name and password and then press
      [Login]. For this, you need to login with
      administrator privileges. Refer to Adding a User
      (Local User List) on page 10-5 for the default login
      user name and password.
      4 Press [Next] of Job Accounting Setting, and then
      [Change] of Job Accounting.
      5 Press [On]. To disable job accounting, press [Off].
      6 Press [OK].
      • blazebusiness
        • 1257
        6 Press [OK].
        User login info was lost and certainly appreciate the reply but-----When you press the System menu key nothing happens. What do you think about trying to clear this in U021 by logging into service mode?
        • subaro
          • Oct 2010
          • 1274
          maybe the system menu is locked out. check with the below sequences and see.
          1087 1087 gets you into service mode.
          U223 Operation panel lock
          Description
          Sets the operation panel lock function.
          Purpose
          This is performed to inhibit operating and canceling the system menu on the operation panel
          which may be done by others then an administrator.
          Setting
          1. Press the start key.
          2. Select the item.
          Initial setting: Unlock
          3. Press the start key. The setting is set.
          Completion
          Press the stop key. The screen for selecting a maintenance item No. is displayed.
          Item No. Description
          Display Description
          Unlock Release the lock of the operation from the system menu
          Partial Lock Lock the operation from the system menu
          • subaro
            • Oct 2010
            • 1274
            To update the above. I think you have to press the
            status job cancel button first and from that screen then the 1087 1087.
