Welcome boot screen taskalfa 250CI
  • brecht2
    • Feb 2012
    • 71
    Hello,
    I've done a downgrade from FW 15 to FW 13.
    After that is got a boot welcome screen, can't pass it at all!
    Tried boot switch with 256MB CF card with FW in root without succes.
    FW update with USB flash --> Error cpu panel (picture attached)
    Also tried again the FW 15 but also without succes.
    Isn't there any solution without changing the Code DIMM, Main PWB or touch panel???
    Thx
  • subaro
    • Oct 2010
    • 1274
    Re: Welcome boot screen taskalfa 250CI
    If you have fax card installed, remove it and then try your update again. if update ok, reinstall fax card and update again.
    • Zackuth
      • Aug 2009
      • 448
      I had one like this. After doing everything according to the troubleshooting guide and a few suggestions from tech support, it turned out that the problem was one of the boards in the op panel. I ended up changing the entire op panel at the suggestion of our tech rep and it is working fine.
      If at first you don't succeed, redefine success
      • brecht2
        • Feb 2012
        • 71
        Hello,
        Fax is already removed.
        I think also it's the OP pwb.
        I swapped the OP to another machine and the same problem.
        The dimm is not the problem.
        I swapped it also and works perfect.
