Kyocera fs 1370 DEVELOPER MISSING message
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Kyocera fs-1370 with DEVELOPER MISSING message, I cleaned from unknown toner the developer unit, added good (correct) toner, put a new toner OEM, also cleaned the drum unit from waste toner, machine is clean. machine was recently serviced in my shop.
    Any ideas are welcomed thanks,
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • copydocinc
    • Mar 2015
    • 263
    Re: Kyocera fs 1370 DEVELOPER MISSING message
    The machine doesn't think the developer unit is installed.
    check connector points on the dev unit and where it contacts inside the machine or in the drum unit.
    You might have to replace the dev unit.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      few times we have seen this it was always non OEM toner...and putting in a new OEM toner fixed it...
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
