kyocera 3035 says jam in finisher/ left door
  • minolta ep310
    • May 2025
    [Error Code] kyocera 3035 says jam in finisher/ left door
    Machine worked fine. moved down hallway started up went in code 00. i think this is right number. from reading in book if you have jam in finisher but turn on/off switch off then on it gets this code.It lights up display that its in left door /finisher open up door and finisher . no paper there. Look for broken off flag /sensor arm? customer wanted machine moved down hall 100 feet. I dont know what i could have done to cause jam code. is 1087 1087 the codes to into still on this model? i usually work on minolta or canon.it got to be something simple. does this have light sensors maybe got paper dust shook down from moving on to sensor thinking its got paper jam. thanks for your help Smarka is no longer running. so here we are.
