With several of the small printers and MFPs that use these 3 Drum units has anyone test to see if they are interchangeable and if so if they ran into any issues?
DK 130, DK 150, DK 170
Re: DK 130, DK 150, DK 170
There are no issues. You can use the DK-150 and DK-170 instead of DK-130, but you will meet a little bit pressure installing a DK-130 in place of DK-170. And that is because of the waste toner sensor which is under the laser unit on the left side. Instead of DK-130 you can use DK-110 and the opposite.Comment
