FS-C2626 Random Streaks
  • JR2ALTA
    • Feb 2010
    • 2033
    I am trying to figure out what causes seemingly random dirty markings on these beasts.
    The streaks are black but client only uses black.
    I vacuumed out the transfer belt and cleaned the IUs. The copy count is only 100k out of 200k PM cycle
    A related question is does anyone like these models? Are they still in production?
    I got a bad impression (no pun in intended) Mainly replacing the feed rollers pissed me off.
  • kyogenius
    • Jul 2012
    • 136
    Re: FS-C2626 Random Streaks
    how are the streaks like ? if you may post the copy samples.however i have encountered the same problems on fs c2126mfp and all i had to do was to lower the value of the MC to 1 in system menu adjustments
    failure is not an option !
    • crazymugs
      • Sep 2013
      • 9
      Can you post a sample picture? Try also doing an altitude adjustment in system menu if you have already checked the drum surface or have replaced black drum and developer.
