I have a Kyocera P6021cdn that has a code 7404. I just started to look at it. Someone else has been servicing it. Here is what I know from the history.
Current meter is B/W 1,076 Color 2,763
In this order:
1.Cyan toner replaced.
2.Code 7404; 0002853 Removed developer (Y) and cleaned
3.Replaced Developer Unit (Y)
4.Code 7403 Removed Cyan Developer unit and cleaned
5.Cyan/Magenta colors off Color Cal. with code 7403; 0003363 Cleaned dev units installed Y and K toner
I did not do these calls but I have to fix it. Any ideas? Are these dev codes an issue for this model? First time on this model.
In this order:
