I have a kyocera eyco m 6535 the machine seems to know blk toner is installed but it's not on the status page or the auditing system it doesnt show up has anyone run into this issue. Im going to order a new sensor but i would think if it was bad it would even know the black toner was installed but maybe im wrong i could really use some advise Please
kyocera eco m6525 not seeing toner
Tags: None
Re: kyocera eco m6525 not seeing toner
m6525 ?????
THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burke -
As far as i know there is no such model as M6525. Correct me if needed OR post the model number from the machine panel.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
ECOSYS M6526cdn? It's the successor to the FS-C2626.
One of my parts manuals lists a M6525 in the filename of this same series but I think it's a documentation error.
e: Found it, ECOSYS M6535cidnComment
Yeh, i know the m6525 replaces the fs-2626. He listed the m6525 and don't see that model listed. However there is an FS-6525 which is qutie a different machine. The importance of posting the exact model when referencing to a specific model. can't read minds as yet.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
I have a kyocera eyco m 6535 the machine seems to know blk toner is installed but it's not on the status page or the auditing system it doesnt show up has anyone run into this issue. Im going to order a new sensor but i would think if it was bad it would even know the black toner was installed but maybe im wrong i could really use some advise PleaseComment
I really cant believe some of the thing you techs suggest. i cant believe your techs you guys would never make it at my place. Very rarely do i see anything you guys suggest thats even close to a fix. Are you techs trained or just wing it. All of these problem are common everyday problems we see here in atlanta. If this machine when you pull a status page if it's not showing up on there it's the sensor board. If it was generic toner the machine would ask you to ok it before continuing. to make you aware it generic toner in this model anywaysComment
ya there is a 6525 under legacy models
Get this. There is no model such as a 6525. There is the FS-6525. If techs are lazy to post the proper model number ,then the advice and troubleshooting could take a very different and expensive course and lots of wasted time. The poster made the correction after proding for the correct model.
wholesaler
I agree with your response for the poster question. I never had to replace the senor board, but reformed the pins that were bent.
By the way, are you sure that sensor board is 1 inch by six inch as you mentioned earlier. Never took out one of those by i am skeptical about that size.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burkeComment
wholesaler
By the way, are you sure that sensor board is 1 inch by six inch as you mentioned earlier. Never took out one of those by i am skeptical about that size.Comment
we just put out a dozen or so of these and we had the same issue with two of them the black wasnt showing up on the auditing system or the status page changed that board and it did the trickComment
