FS-C8520MFP Jam 4211
  • simon_carter
    [Jamming] FS-C8520MFP Jam 4211
    Hi All
    We have a FS-C8520MFP which keeps jamming with a 4211 error which I believe is the eject sensor. The attached document suggest replacing a spring in the fuser, however we have installed a maintenance kit on the machine which includes a new fuser (paper is constantly jamming in the fuser). Should the new fuser not have resolved the issue?
    Any advice is greatly appreciated.
    Simon
  • mccasian
    Re: FS-C8520MFP Jam 4211
    I have exactly the same problem. Does anyone found a solution?
    • simon_carter
      Hi.
      We ended up passing over to some printer engineers to complete the job and I believe they resolved by turning the duplexer or belt over?
      • copier parts n.ireland
        • Nov 2016
        • 41
        ive had a exit sensor lever sticking on this utax 5025 series equivalent,not the sensor on fuser,final black lever when paper finally gets out ,remove side cover above fuser,remove 2 screws and cable,comes out as an assembley.its worth checking
