TaskAlfa 4500i
  • Reed
    • Feb 2011
    • 261
    TaskAlfa 4500i
    This machine makes a whining/humming noise when copying. The noise will continue for a few seconds after the copy/print is made. Sometimes it gets quite loud and other times you can barely hear it. I checked and the machine is in the silent mode. I am thinking it may be the fuser has anyone else had this problem? Thanks in Advance
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: TaskAlfa 4500i
    I would check the fan on the main pwb..
    • wragsdale
      • Jul 2014
      • 188
      Re: TaskAlfa 4500i
      Idle rollers, fans, clutches, drum, bushings, gears.
      U030, U031, U037, U243 (DP) .
      General TB 91. Junction wire to cheat main innerlock which can help troubleshooting a noise.
      • tech28
        • Jun 2013
        • 434
        Re: TaskAlfa 4500i
        Fan, put your hand in the back and press, back cover pushed in?
        • daveh12
          • Jul 2012
          • 157
          Re: TaskAlfa 4500i
          Fusers on this this model can get very noise from time to time. Test the fuser from maintenance mode. And Replace if needed.
