I have a 300i that I need to install Pinpoint scan on. I have the older version 1.0 that tech support said I needed. I was also instructed to update the firmware to 9.0 which I have. My issue is that the procedure on the Pinpoint 1.0 is not the same as the current 2.0 and tech support cannot find any documentation on the install procedure. Does anyone have an documentation or advice as to how to get this done?
Taskalfa 300i pinpoint scan
Re: Taskalfa 300i pinpoint scan
There's no 300i under supported models in 2.0. It might work with 1.x. There's no documentation for 1.x that i know of. Shouldn't be much different from 2.0. You will need version 1.x .pkg file and the license for it. Also you will need pinpoint.exe to set it up on PCs.
