KYOCERA FS-1028MFP
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] KYOCERA FS-1028MFP
    Hello all .. if l started this fs-1028mfp ...he function good so if l want copyed this message affiched there ( Cassette1 not loaded ) ..l try clean detector but any chance ..pls help .
    BEST TECHNICIAN . NICE PEOPLE .
    Re: KYOCERA FS-1028MFP
    Improvement of the Preventive Margin for the Paper Detection Actuator
    fs 1028 casette.pdf
    • zaza
      MECANOGRAPHE
      • Mar 2008
      • 1095
      [ATTACH]32415[/ATTACH]
      thank you ..l change this paper detecion actuator by another same model but unfortunate any solution ..pls any other idea
      • JR2ALTA
        • Feb 2010
        • 2030
        If it's true that you have another model machine to swap parts you should be OK. It's either the tray, the sensor or the actuator. Sensor and board issues are rare on this model. Is the tray lifting? Have you determined it's not just looking for plain paper while the machine is set for thick?
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          thank you very much all friends ..l solved my problems ...only cleaner this detector paper parts ...thank you again .
