Error code C0150
+ More Options
Posts
  • Nito
    • Feb 2016
    • 1
    Error code C0150
    Good Morning any idea how to fix error code c0150 in Kyocera FS-3140MPF+
  • laitang
    • Nov 2012
    • 627
    Re: Error code C0150
    C0150: Engine PWB EEPROM error
    Detecting engine PWB EEPROM communication error.
    Posible Causes & Check proceduce:
    - Improper installation engine PWB EEPROM: Check the installation of the EEPROM and remedy if necessary.
    - Defective engine PWB: Replace the engine PWB and check for correct operation
    • Kyo fan
      • Dec 2013
      • 368
      Upgrading to the latest firmware should resolve it. If it doesn't, it's either engine or main pwb that needs to be replaced.
      • taskalfaman
        • Nov 2009
        • 137
        I had one case developing unit, otherwise, try to do update.
        if not ask @ kyo a new engine eprom.
        • delsignore2410@rogers.com
          • Nov 2015
          • 5
          [QUOTE=taskalfaman;513817]I had one case developing unit, otherwise, try to do update.
          if not ask @ kyo a new engine eprom.[/QUOTe Most of you are over analyzing this error. Replace toner which is most likely generic, with genuine Kyocera toner. And the code will disappear.
