Hello, I just serviced this machine Kyocera KM3035, and produces copies with the back of the page stained in black, I noticed the transfer roller is contaminated (and the drum also has a slight toner coat, I believe all of these symptoms are related, I have changed toner as well(cleaning the U.R.inside+out beforehand) and still the same, changed drum + blade for new ones and still the same.
Any ideas are welcomed
thanks!!
P.S. I also checked the preclean (discharge) lamps and they're connected Ok.
thanks!!
