Duplex printing margins are off
  • Neocortex
    • May 2016
    • 8
    [Misc] Duplex printing margins are off
    Hello! I've purcheched a Kyocera ecosys M6026cdn copier yesterday, and I have a problem with the duplex printing function. If I print on 80gms plain papers the margins are nearly perfect, however with 160gms papers the second print's alignment is way off horizontally (in landscape printing) it touches the left side of the paper. I've tried to set it to thick paper in printer and driver settings too, modified it to "extra heavy" but it doesn't affected the outcome. Can you please advise how can I fix the margins?
    P.S: non-duplex mode produces proper margins with the 160gms papers
  • jhalfhide
    • Apr 2015
    • 451
    Re: Duplex printing margins are off
    I think you'll find that on that type of machine it is simply "within spec". It's not a production or even entry level production machine so the tolerances will be high. Nobody will go any further than that on it.
