Kyocera fs-c5250dn
  • Orion2010
    • Jun 2015
    • 176
    Kyocera fs-c5250dn
    Hello to all, I have Kyocera fs-c5250dn I replace the black toner but again says replace toner K. I test with 5 toners but nothing
  • correo.tony
    • 72
    Re: Kyocera fs-c5250dn
    Hy !
    replace developer unit K ( DV-590K ), if no rules, replace toner k motor assy,
    Bye
    • Alexkyocera
      • Jul 2015
      • 82
      Originally posted by correo.tony
      Hy !
      Bye
      Check tranfser belt auguer, to ensure its not blocked, also the left side of the machine at 4 couplers that engages the toner, ensure they move freely when u open the top cover.
      If all fails you might have to installed the retrofit for this unit.
      • subaro
        • Oct 2010
        • 1274
        Hy !
        Bye
        I agree with the above, only there is a mod kit for the toner motor assy that you can order parts for. the parts are cheap and the installation is simple enough if you follow the instructions on the mod kit. The instructions can be found on this forum. do a search for fs-2626 . also check transfer belt ports as mentioned already
