network Status report
  • heera
    • Jul 2009
    • 8
    [Misc] network Status report
    Can any one assist how to schedule network status report through email from command center in TASKalpha 3051ci.
    to get the monthly toner cover age information from the MFP
  • just a tech
    • Jan 2007
    • 332
    Re: network Status report
    The menu settings are hidden within a special notification menu in the machine's web interface..
    • Open your web browser.. Type in "Machine's IP Address/svcmntrpt".. This will open the menu for the service report print.. (For example : 192.168.192.125/svcmntrpt)
    • Configure which reports you want sent and at what intervals you want them by filling in the required fields and reporting preferences..
    • Can select from either "Maintenance Report", "Event Log", "Network Status Page", "Service Status Page", "Status Page", & "Application Status Page".. Or you can check all of the boxes so as to receive all of them at your selected intervals..
    • The "Service Status Page" is the report that will show you percentages for Coverage..
    • You will also need to configure the SMTP information on the webpage as well.. Although the machine may already be configured for sending e-mails, this particular webpage function does not access & utilize the current SMTP Server information that is stored in the device for normal day-to-day e-mailing by the end-user.. Therefore, you must enter in the necessary SMTP information so as to allow for the e-mailing of the Maintenance Pages to the e-mail address that you entered for the recipient..
    P.S. -- Below the Toner Cover values listed on the Service Status Page, you will see the "Period" for which the machine has tracked the coverage data.. Example : (06/11/2015 - 05/31/2016 09:07)
    If you want this period reset, you can reset that within Maintenance Mode 910
    Hope this helps..
    JaT
