Code reset counter copy FS-3640
  • masky
    • Aug 2010
    • 43
    [Error Code] Code reset counter copy FS-3640
    Hello I need help, have a Kyocera Fs3640 and need to lower the total book-keeper of the machine, it is possible in this model? I it do not want to put to 0, only to put less quantity.
    I am a technician and need to return to sell the product
    Thank you
  • subaro
    • Oct 2010
    • 1274
    Re: Code reset counter copy FS-3640
    Thank you
    Why don't you sell the machine with the current meter read. Is that not being honest to the one who is going to buy the unit. reducing the meter read will be telling a false history of the machine, isn't it.
    • Kyo fan
      • Dec 2013
      • 368
      You can do that only once with U927, but that is if the total counter is under 1k, and that's it. The other "trick" is to replace the eeprom on the main board which will contain lower counter, but that will also change the serial number, etc.
      • masky
        • Aug 2010
        • 43
        REPLACING the EPROM change the serial number, but not is important to my, then, there is possibility of buy an EPROM or modify the current?
        the motive is not to distort the history, as it is a machine that I give maintenance but is more easy sale if less than 300 k is copies
