Kyocera M6535cidn - f234 / f183 error codes
  • kuby
    • Oct 2007
    • 1410
    Have M6535cidn giving a F234 and F183 code. Cannot find it in the manual. Was trying to copy Single sided to 2 sided and it took the pages in the document feeder and then it was like it was waiting on another sheet. A piece of paper feed part way out of the cassette and then the machine just continued to run. I open the back and the paper was partially fed out of the cassette and when I took the paper out and closed the back of the machine then the F234 or F183 error shows up. ????
  • Smircea
    • 15
    Re: Kyocera M6535cidn - f234 / f183 error codes
    Hello.
    you could try this :
    1) Check contact of the DDR memory. Reinsert after u clean all the dust.
    2) Format the HDD and check function. (U024 FULL formatting)
    3) Execute the U021 Memory initializing to initialize the controller backup memory
    and check function.
    Easy 3 steps. If none works try to reinstall your firmware.
    Jamming issue sounds like your fuser exit sensor is faulty. Can try to put a 0.1mm on it and this sould fixt the problem.
    Best of luck.
    • kuby
      • Oct 2007
      • 1410
      Forgot to mention that this machine is just 2 weeks OLD.
