Fax System (W) for TASKalfa 2550ci
  • kyove
    • Apr 2015
    • 62
    Hi Folks,
    I have a question: is it possible to install a fax system (W) taken from a TA 2550ci to a TA 2551ci?
    I know that:
    • TA 2550ci > Fax System (W)
    • TA 2551ci > Fax System (W) B
    Anyone knows?
    Thank you in advance,
    Kyove
  • wragsdale
    • Jul 2014
    • 188
    Re: Fax System (W) for TASKalfa 2550ci
    It's actually Fax System (V) that's installed in the 0 series Alphards and they are not interchangeable. Sorry!
    edit: Whoops! I'm wrong. You are correct about the versions that go to each machine. I doubt they work together, though.
    • simonsays
      • Aug 2013
      • 95
      Originally posted by kyove
      hi folks,
      i have a question: Is it possible to install a fax system (w) taken from a ta 2550ci to a ta 2551ci?
      I know that:
      • ta 2550ci > fax system (w)
      • ta 2551ci > fax system (w) b
      anyone knows?
      kyove
      yes you can just reset the fax dimm i beleave its 691 or around there it's the same board
      • pascalb.
        • Aug 2016
        • 47
        Hello
        Fax board W possible on 2550
        Fax board W (B) possible 2550 & 2551
        Good day
        Pascal.
        Do not lament,
        do not mock,
        do not hate,
        but understand.
