Kyocera P6035cdn error C4600
  • The Cleaner
    • May 2025
    [Error Code] Kyocera P6035cdn error C4600
    Hi Guys,
    I've been stuck with a Kyocera ECOsys P6035cdn that is driving me crazy!!!, it keeps giving me a C4600 error which is the LSU cleaning motor error.
    To date:
    -> I've upgraded to the latest available firmware,
    -> Followed the LSU cleaning motor service bulletins and greased the relevant gears and shafts,
    -> Replaced the Engine Relay as prescribed in the service manual.
    STILL NO JOY!!!
    Anybody have any other options for me to try or ideas other than matches and petrol?
    Thanks.
  • TECHKYO
    • Aug 2016
    • 15
    Re: Kyocera P6035cdn error C4600
    there is bulletin for the same code
    • The Cleaner
      @TECHKYO, Yes...I saw the service bulletin and did the modifications but the error msg: C4600 still comes back.
      • tee
        • Aug 2014
        • 79
        unplug the cleaning motor from the pcb
        It has been working so far.
        • The Cleaner
          Unplugged the LSU Cleaning motor and it works...had to eventually replace the laser assy A&B to fix the problem
          • Robob
            • Dec 2011
            • 21
            I've got a couple of M6535cidn in a very dusty warehouse with the same problem. I've unplugged the cleaning motors on both, which got rid of the codes, but I have to manually clean them every few weeks, which is getting old!
            If replacing the LSUs would make a permanent fix I would gladly do it, but I haven't seen anything about modifications to them.
            So, it's been a while since you replaced both LSUs... Did that permanently fix the problem???
            Thanks for your reply,
            Robert B.
            Atlanta, GA
            • lees
              • Apr 2011
              • 94
              We have modified several of this series machines with some success. We have found that the cleaning motor will need to be replaced and possibly the left connect board to eliminate the error code. While replacing the motor, you can modify the lasers with mylar pieces to help the cleaners get on the glass of the laser. This has eliminated the problem on several machines for us. I will post a link to a video that we made describing the modification. I have sent this to Kyocera with no response from them except that they have tried it also with success, but never bothered to let anyone know about it.
              • Unitech Blake
                I tried all of the above, but I wasn't settling on having to go back once a month to pull the 4 devs, 4 drums, belt, 4 toners out and wipe 4 slits of glass because of a unplugged motor. I replaced the "Inner Left Duct" (pn= 302NR33020) which is the black plastic housing for the drive train for all 4 LSU cleaners. Don't forget to grease those gears either. Fairly easy job after having to pull everything out a dozen times.
